How to actuate Fan Airflow through Python
Hi,
I am a beginner to energy modelling and I am working on modulating Fan Speed through a logic. I have tried every method, I have added Variable Fan and its mass flow rate in the list of EMS Actuator as well. I am adding the details in the code but I am not getting what details is being missed here !!
!-   ===========  ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:SENSOR ===========
EnergyManagementSystem:Sensor, Energy_Management_System_Sensor_1, !- Name Fan Variable Volume 1, !- Output:Variable or Output:Meter Index Key Name Fan Air Mass Flow Rate; !- Output:Variable or Output:Meter Name
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:ACTUATOR ===========
EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_2, !- Name Thermal Zone 1, !- Actuated Component Unique Name Zone Temperature Control,!- Actuated Component Type Cooling Setpoint; !- Actuated Component Control Type
EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_3, !- Name Thermal Zone 1, !- Actuated Component Unique Name Zone Temperature Control,!- Actuated Component Type Heating Setpoint; !- Actuated Component Control Type
EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_4, !- Name Fan Variable Volume 1, !- Actuated Component Unique Name Fan, !- Actuated Component Type Fan Air Mass Flow Rate; !- Actuated Component Control Type
Hi,
Name !- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:ACTUATOR ===========
=========== EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_2, !- Name Thermal Zone 1, !- Actuated Component Unique Name Zone Temperature Control,!- Actuated Component Type Cooling Setpoint; !- Actuated Component Control Type
Type EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_3, !- Name Thermal Zone 1, !- Actuated Component Unique Name Zone Temperature Control,!- Actuated Component Type Heating Setpoint; !- Actuated Component Control Type
Type EnergyManagementSystem:Actuator, Energy_Management_System_Actuator_4, !- Name Fan Variable Volume 1, !- Actuated Component Unique Name Fan, !- Actuated Component Type Fan Air Mass Flow Rate; !- Actuated Component Control TypeType
Thanks.
Hi,
Thanks.
