How to solve HVACTemplate Termination in eppy?
Hi there,
I have a challenge in running a simulation for a super-duper house for the HVAC system.
Here is the eplusout.err details:
Program Version,EnergyPlus, Version 23.2.0-7636e6b3e9, YMD=2024.06.02 12:58, * Warning * Version: in IDF="23.1" not the same as expected="23.2" * Severe * HVACTemplate:* objects found. These objects are not supported directly by EnergyPlus. * ~~~ * You must run the ExpandObjects program on this input. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=1 ..... Last severe error=HVACTemplate:* objects found. These objects are not supported directly by EnergyPlus. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 0.04sec
Could you kindly let me know how I could tackle the challenge?
Thanks very much in advance.
Sincerely, Behnam
