My model has lot of windows (4 typical sizes) and is modelled using floorspace js embedded in openstudio. The idf file maps windows with vertex information format (GlobalGeometryRules, UpperLeftCorner, !- Starting Vertex Position!, refer to sample image window object in IDF) image description. Ihave around 60 windows in my building. so if i want to use jeplus for parametric simulation of these windows by changing height, or width. what is the easiest way to do this. I referred to the tutorial provided in youtube, but the IDF format given there is from design builder modelling and is shown only for one particular window; But for OS, floor space editor models it in a different way. I found some materials about EP macros, but I couldn't find any proper guide or tutorial. If there is an easy way to manipulate the windows and Shading (shading is also similar problem),. Please let me know.
