Hi, I am still struggling with how to overwrite supply air temperature or flow rate or just simple Phvac in EnergyPlus, by its Python API. Here is something I tried:
1) getting actuator_handle
"api.exchange.get_actuator_handle(state, "System Node Setpoint", "Temperature Setpoint","AIR LOOP OUTLET NODE_UNIT1")"
2) overwrite
def overwrite(state):
if api.exchange.warmup_flag(state) == 0:
supply_temp = 12
supply_flow = 0.5
api.exchange.set_actuator_value(state, supply_temp_handle, supply_temp)
api.exchange.set_actuator_value(state, supply_flow_handle, supply_flow)
state = api.state_manager.new_state()
api.state_manager.reset_state(state)
api.runtime.callback_begin_zone_timestep_after_init_heat_balance(state, overwrite)
However, this way does not work. (Nothing updated)
I tried so many things, but I feel only the temperature setpoint, which is schedule-based, can be overwritten correctly. Is there anyone who could help me with it?
Thank you!
