Hiho,
When trying to simulate a example fmu file with pyfmi:
try:
model.initialize(start_time, stop_time)
result = model.simulate(start_time=start_time, final_time=time_stop, time_step=time_step)
except Exception:
print(model.get_log())
i get the error (and it makes no difference if i change the start or stop or step time, these parameter seem to have no effect here):
['FMIL: module = Model, log level = 2: [error][FMU status:Error] fmi2EnterInitializationMode: The delta between the FMU stop time 1.000000 and the FMU start time 0.000000 must be a multiple of 86400. This is required by EnergyPlus. The current delta is 1.000000. Instantiation of Model failed.', '']
has anyone a solution to this error?
