Hi Im tying to run an model on a building in openstudio and the simulation keeps failing with the following message:"* Severe * HVACTemplate:* objects found. These objects are not supported directly by EnergyPlus. * ~~~ * You must run the ExpandObjects program on this input." I turned on Ideal Air loads and dont have any HVAC systems included. Can someone give me some advise on how to remedy this. I have no idea how I fix this
