We are using an openstudio. We use the waste heat from the data center to heat the smart farm using the vrf system, which gives a positive load on one side and a negative load on the other side with the same value. When both are given positive loads, they still seem to be well controlled, but when they are given negative loads, they are not controlled. Is there no problem if I give you both plus loads?
