Hello, im newbie in Openstudio. I try to run a simple simulation for my university project, but it shows "Simulation failed to run, with exit code 1". I try to find and read and find the error but i don't know where and what it is.
This is what it said :
Program terminated: EnergyPlus Terminated--Error(s) Detected.
[00:17:27.380298 DEBUG] Path for the OSW: C:/Users/user/AppData/Local/Temp/osmodel-1715788515-0\resources\workflow.osw
[00:17:27.415917 DEBUG] Initializing run method
[00:17:27.425050 DEBUG] Beginning run
[00:17:28.614048 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[00:17:28.614703 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:223:in call_energyplus'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'
:/openstudio_cli.rb:1173:in execute'
:/openstudio_cli.rb:803:inexecute'
:/openstudio_cli.rb:1972:in <main>'
eval:188:ineval'
eval:188:in require_embedded_absolute'
eval:173:inblock in require_embedded'
eval:167:in each'
eval:167:inrequire_embedded'
eval:126:in require'
eval:3:in<main>'
[00:17:28.616579 ERROR] Found error in state 'simulation' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:223:in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'\n:/openstudio_cli.rb:1173:in execute'\n:/openstudio_cli.rb:803:inexecute'\n:/openstudio_cli.rb:1972:in <main>'\neval:188:ineval'\neval:188:in require_embedded_absolute'\neval:173:inblock in require_embedded'\neval:167:in each'\neval:167:inrequire_embedded'\neval:126:in require'\neval:3:in<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:241:in rescue in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:238:incall_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1173:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1972:in<main>'\neval:188:in eval'\neval:188:inrequire_embedded_absolute'\neval:173:in block in require_embedded'\neval:167:ineach'\neval:167:in require_embedded'\neval:126:inrequire'\neval:3:in `<main>'"]}
