Hello everyone,
I have a problem with connecting the HP (air-to-water) in EnergyPlus. The problem is that the heat pump is connected to VRF units in the room, and the HP is also connected to a hydrobox (Heat Exchanger-Fluid to Fluid) that sends to floor heating/cooling in the same room. Simply put, fluid flows through the system to the VRF and hydrobox, while on the other side there is water.
Has anyone else experienced a similar problem or knows how to solve it?
A big thank you to everyone.
