asked Apr 9
Mike117's avatar
Why do I get 'Cooling Design Supply Air Temperature=[25.00]' and 'Heating Design Supply Air Temperature=[20.00]' severe errors? ?
My understanding is that I am setting the heating and cooling temperature setpoints. For instance, if the thermal zone is at 25C or hotter it will cool. My understanding maybe incorrect here.
The error I received in the eplusout.err file is the following:
Cooling Design Supply Air Temperature=[25.00] * ~~~ * This is not allowed. Please check and revise your input. * Severe * Sizing:Zone="TZ - S6 - FCU 2" has invalid data. * ~~~ * ... incorrect Zone Heating Design Supply Air Temperature=[20.00] is less than Zone Cooling Design Supply Air Temperature=[25.00] * ~~~ * This is not allowed. Please check and revise your input. * Severe * Sizing:Zone="TZ - S6 - TOILETS" has invalid data. * ~~~ * ... incorrect Zone Heating Design Supply Air Temperature=[20.00] is less than Zone Cooling Design Supply Air Temperature=[25.00] * ~~~ * This is not allowed. Please check and revise your input. * Fatal * Sizing:Zone: Errors found in getting input. Program terminates.
How should I resolve this issue? I changed the temperature setpoints but the issue persists.
 *   ~~~   * **   ~~~   ** This is not allowed.  Please check and revise your input.
 * ** Severe  * ** Sizing:Zone="TZ - S6 - FCU 2" has invalid data.
 *   ~~~   * **   ~~~   ** ... incorrect Zone Heating Design Supply Air Temperature=[20.00] is less than Zone Cooling Design Supply Air Temperature=[25.00]
 * ** Severe  * ** Sizing:Zone="TZ - S6 - TOILETS" has invalid data.
 * **  Fatal  * ** Sizing:Zone: Errors found in getting input. Program terminates.
terminates.
How should I resolve this issue? I changed the temperature setpoints but the issue persists. persists.
** Severe  ** Sizing:Zone="TZ - S6 - FCU 2" has invalid data.
** Severe  ** Sizing:Zone="TZ - S6 - TOILETS" has invalid data.
**  Fatal  ** Sizing:Zone: Errors found in getting input. Program terminates.
