How do I resolve surface construction matching conflicts between Surface X and Surface Y? How do I resolve the following error "Polyhedron is not enclosed in original testing. Trying to add missing colinear points. Polyhedron is not enclosed." ?
I tried manually resolving the surface construction mismatch by matching the construction materials. The errors return after I rerun the simulation. I obtain errors like below:
Could not resolve matched surface construction conflicts between surfaces 'Face 1250', and 'Face 1267' Could not resolve matched surface construction conflicts between surfaces 'Face 1304', and 'Face 1264' Could not resolve matched surface construction conflicts between surfaces 'Face 1230', and 'Face 1296'
I have redone the spaces in FloorspaceJS that are called out with the following error message, but the error persists. Error message below.
" Polyhedron is not enclosed in original testing. Trying to add missing colinear points. Polyhedron is not enclosed. Object of type 'OS:Space' and named 'Wet Lab 1' is not enclosed, there are 1 edges that aren't used exactly twice. Falling back to ceilingHeight * floorArea. Volume calculation will be potentially inaccurate. Object of type 'Schedule:Constant' and named 'Always Off Discrete', points to an object named OnOff 2 from field 1, but that object cannot be located. Object of type 'Schedule:Constant' and named 'Always On Continuous', points to an object named Fractional 1 from field 1, but that object cannot be located. "
I posted two questions which are in the same failed simulation. Please let me know if this against posting rules.
Let me know if providing my model will help with troubleshooting.
1296'
Let me know if providing my model will help with troubleshooting. troubleshooting.
How do I resolve surface construction matching conflicts between Surface X and Surface Y? Y in the Openstudio APP - FloorspaceJS? How do I resolve the following error "Polyhedron is not enclosed in original testing. Trying to add missing colinear points. Polyhedron is not enclosed." ?
Edit: This is a link a to the google drive where my model is stored. Link : https://drive.google.com/drive/folders/1tL6ghJ2tHihvcGWL37C-wHx-aNN9_Bnb?usp=drive_link
How do I resolve surface construction matching conflicts between Surface X and Surface Y in the Openstudio APP - FloorspaceJS? How do I resolve the following error "Polyhedron is not enclosed in original testing. Trying to add missing colinear points. Polyhedron is not enclosed." ?
Edit: This is a link a to the google drive where my model is stored. Link : https://drive.google.com/drive/folders/1tL6ghJ2tHihvcGWL37C-wHx-aNN9_Bnb?usp=drive_link https://drive.google.com/drive/folders/1tL6ghJ2tHihvcGWL37C-wHx-aNN9_Bnb?usp=sharing
