Hi Everyone,
I am using jEPlus+EA for doing Sensitivity Analysis. under the algorithm setting, in sampling method, I chose the SALTELLI method. However, after I clicked "create project" the sampling methodology would always change to the MORRIS method and this issue allows me to can not use the SALTELLI as the sampling method.
does anyone have the same problem?
Looking forward to your help. Thanks in advance! Regards, Mike
Regards, Mike
