Hello,
I was previously trying to figure out the CO2 EMS code which I was able to get working. Essentially, I want my model to access the Natural Ventilation with the Temperature control and CO2 sensors together. But, the results I've noticed is that with the CO2 EMS script, the temperature control has been disregarded. I've tried to include both temperature control and CO2 sensors in my script but havent had any luck.
CO2 Control
CO2_Sensor09, !- Name
IF EMS_CO2_Sensor07 > 800, !- Program Line 1
SET OpenFactor09 = 1.0, !- Program Line 2
ELSE, !- A4
SET OpenFactor09 = 0.0, !- A5
ENDIF ;
Temp Control
Temp_Program02, !- Name
IF Temperature_Sensor01 > 23, !- Program Line 1
SET Temp_OpenFactor01 = 1.0, !- Program Line 2
ELSE, !- A4
SET Temp_OpenFactor01 = 0.0, !- A5
ENDIF ; !- A6
EMS control with both Temperature and CO2. This does not work, maybe due to an error in my EMS sensor script below. I had to seperate the Output variables as it would not work when "Zone Air CO2 Conc" and "Zone Air Mean Temperature" Ran together.
EnergyManagementSystem:Sensor,
EMS_CO2_Sensor09, !- Name
SecondFloorStudy, !- Output:Variable or Output:Meter Index Key Name
Zone Air CO2 Concentration; !- Output:Variable or Output:Meter Name
Temperature_Sensor01, !- Name
AtticBedroom-cutout, !- Output:Variable or Output:Meter Index Key Name
Zone Mean Air Temperature; !- Output:Variable or Output:Meter Name
OpenFactor01, !- Name
Window_4_Opening, !- Actuated Component Unique Name
Zone Ventilation, !- Actuated Component Type
Air Exchange Flow Rate; !- Actuated Component Control Type
AND Temperature_Sensor07 > 26, !- Program Line 2
SET OpenFactor09 = 1.0, !- A4
ELSE, !- A5
SET OpenFactor09 = 0.0, !- A6
ENDIF ; !- A7
This is the error I get when I run the above script
1. ** Severe ** Errors found parsing EMS Runtime Language program or subroutine = CO2_SENSOR01
Can anyone help me figure out the script that could include both temperature and CO2 control?
Cheers, Adarsh
