Hi there,
For the parameters on Energyplus under the Annual Thermal Resilience Report. What is the difference between Heat Index, Heat Index OccupantHour, Heat Index OccupiedHour?
OccupantHour is the accumulated hours for the sum of all occupants in a space. But I'm slightly confused on the other two.
Thanks!
