Error Message: Cannot find an E+ installation to handle model version 23.2 of the project! Warning: no report variable is defined. This project may not work with jEPlus+EA.
Hi there,
I'm trying to run energy simulations through JEPlus v2.1.0 with the energyplus version 23.2. However I keep running into this error message when validating the project:
"Cannot find an E+ installation to handle model version 23.2 of the project! Warning: no report variable is defined. This project may not work with jEPlus+EA."
I was wondering if this has anything to do with the compatibility of the newest EP version to JEPlus. Is there a quick work around or is the only option to downgrade the IDF file to be compatible to JEPlus?
Thanks!
