Hello All,
I am attempting to use the UrbanOPT DES functionality, and have hit an issue when trying to generate the system parameters JSON file. When running the des_params command, the program confirms that all packages are installed (ThermalNetwork, urbanopt-ditto-reader, NREL-disco, and geojson-modelica-translator), but then stops running and does not generate the system parameter file.
I have installed python and followed the steps for the DES workflow shown in their documentation here: https://docs.urbanopt.net/installation/des_installation.html
If anybody has any insight it would be much appreciated!
