I am trying to use the building rotation measure using PAT 3.7.0 to simulate the building rotations per Appendix G of ASHRAE Std 90.1. The results I am getting are: run status saying completed datapoint failure and no warnings and errors. There are no EnergyPlus warning and error messages appearing in the results window. Also, the datapoint information page does not show the seed model and weather file in the respective field values, so I am thinking that maybe PAT is not reading these files, hence, the datapoint failure and no warning/error messages in the results. I re-entered the seed file and weather file several times and reinstalled PAT but I am still getting the same results. The images of the results, datapoint information, and design alternatives pages are attached if these could be of help in figuring out what is causing the error. Any advice on how to make the simulation run is much appreciated. Thank you.
