When opening an 1.4.0 osm-file with OpenStudio 1.8.0 in the plant loop schematic the symbol for a setpoint gets lost, although apparently the data associated with the setpoint manager have been read in.
| 1 | initial version |
| 2 | No.2 Revision |
setpoint manager
| 3 | No.3 Revision |
When opening an 1.4.0 osm-file with OpenStudio 1.8.0 1.8.0, in the plant loop schematic the symbol for a setpoint manager
| 4 | retagged |
When opening an 1.4.0 osm-file with OpenStudio 1.8.0, in the plant loop schematic the symbol for a setpoint manager gets lost, although apparently the data associated with the setpoint manager have been read in.
| 5 | No.5 Revision |
In the following instances I have observed that in the OpenStudio 1.8.0 HVAC schematic the setpoint manager symbol gets lost:
(1) If Control Variable is set to Maximum Temperature, the SPM symbol disappears, including the
visual handle for deleting the setpoint manager.
(2) When opening an 1.4.0 osm-file with OpenStudio 1.8.0, in the plant loop schematic the symbol for a setpoint manager
manager gets lost, lost if Control Variable was set to Maximum Temperature in the 1.4.0 osm-file, although apparently the data associated with the setpoint manager have been read in.in.
Apparently this is a new bug which did not exist in previous version(s).
