Anyone know why these warnings are showing?
I defined two zones, one within the other.
Program Version,EnergyPlus, Version 9.2.0-921312fa1d, YMD=2024.02.04 20:05,
** Warning ** CalculateZoneVolume: The Zone="OUTER ZONE" is not fully enclosed. To be fully enclosed, each edge of a surface must also be an edge on one other surface.
** ~~~ ** The zone volume was calculated using the opposite wall area times the distance between them method
** ~~~ ** The surface "iz-INNERZONE WALL 1" has an edge that is either not an edge on another surface or is an edge on three or more surfaces:
** ~~~ ** Vertex start { 1.0000, 1.0000, 0.0000}
** ~~~ ** Vertex end { 1.0000, 4.5000, 0.0000}
** ~~~ ** The surface "iz-INNERZONE WALL 2" has an edge that is either not an edge on another surface or is an edge on three or more surfaces:
** ~~~ ** Vertex start { 5.0000, 1.0000, 0.0000}
** ~~~ ** Vertex end { 1.0000, 1.0000, 0.0000}
** ~~~ ** The surface "iz-INNERZONE WALL 3" has an edge that is either not an edge on another surface or is an edge on three or more surfaces:
** ~~~ ** Vertex start { 5.0000, 4.5000, 0.0000}
** ~~~ ** Vertex end { 5.0000, 1.0000, 0.0000}
** ~~~ ** The surface "iz-INNERZONE WALL 4" has an edge that is either not an edge on another surface or is an edge on three or more surfaces:
** ~~~ ** Vertex start { 1.0000, 4.5000, 0.0000}
** ~~~ ** Vertex end { 5.0000, 4.5000, 0.0000}
