Hello,
I'm really lost and need your help. I installed pyenergyplus.api / NBNL V 23.2 and try to run a simple idf file as a test. The run throws an error eplusout.err, that I didn't specify a weather.epw file. I tried chatGPT, but it refers to a IDF and Weather class in energyplus.api which aren't ther in the 23.2 version ...
- can you guide me to a detailed API description for version 23.2?
- can you provide a running example?
Thank you
