Hello,
I am trying to put some setup for the HVAC system: 1/ I want the cooling mode to be running from May 1st until Oct 1st the setpoint should be 25C° the Heating would be on if the temp goes below 16C°. 2/ The heating mode should be on from Oct 1st Until May 1st the setpoint should be 22C°and the cooling would be on if the temp went above 30C.
How can I do that ?? I am learning but this thing was difficult.
