I am trying to use the Table:Lookup object with a link to external csv file. The InputOutput reference and Engineering reference does not show an example for this. How do I name the file and where do I put it? No matter what value I put in the field !- External File Name OpenStudio seems to delete it.
OS:Table:Lookup, {9eed7d77-62eb-495e-9bea-ea44b3858990}, !- Handle Table M Variable Lookup P72TNU_YNU, !- Name {b141d15d-7390-419d-9adc-ed54aa376acf}, !- Independent Variable List Name DivisorOnly, !- Normalization Method 1, !- Normalization Divisor 0.38, !- Minimum Output {BasedOnField A5} 1.243, !- Maximum Output {BasedOnField A5} Dimensionless, !- Output Unit Type , !- External File Name 3, !- External File Column Number 1; !- External File Starting Row Number
