Hi everyone,
I'm a beginner with Openstudio and I currently try to make the PTHP component to work but without success. In the Thermal Zones section, I simply drag and drop the component from the library to the corresponding thermal zone.
I then run the simulation and the following error message ensue:
* Severe * <root>[Coil:Cooling:DX:SingleSpeed][PTHP 1 Spd DX Clg Coil] - Missing required property 'air_inlet_node_name'.
* Severe * <root>[Coil:Cooling:DX:SingleSpeed][PTHP 1 Spd DX Clg Coil] - Missing required property 'air_outlet_node_name'.
Does that mean that I need to create an Air Loop or something similar for it to work?
If I replace the PTHP with a basic electric baseboard component it works fine.
I run the latest OpenStudio release (1.6)
Thank you for your help!
