I'm using an analysis finalization script to try to save my OS server job's eplusout.sql files to cloud storage. For each datapoint, the script gets the datapoint.zip, extracts the files of interest (eplusout.sql & a few others) and saves them to my cloud storage location.
The problem I'm running into is that the eplusout.sql files don't get consistently saved to the datapoint zip files. Based on https://unmethours.com/question/26789/missing-eplusoutsql-after-running-pat/, it seems there is a size limit above which they will not get included in the datapoint.zip.
Is there a way to disable this size limit, or access the eplusout.sql file outside of the datapoint.zip?
Thanks!
