Severe ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 10" did not converge after 25 warmup days.
How should I resolve that, This is a 600,000 sqft model, I was running it with 5 warmup days for the sim speed, increasing it to 40 still I am getting the error, Simulation runs perfectly fine until May and then stops because of this error, I have checked all the Internal loads, construction everything seems correct.
* ~~~ * Environment=NEW YORK J F KENNEDY INTL AR ANN CLG .4% CONDNS DP=>MDB, at Simulation time=07/21 00:00 - 01:00 * Severe * CheckWarmupConvergence: Loads Initialization, Zone="CORRIDOOR- LEVEL-2" did not converge after 25 warmup days. * ~~~ * See Warmup Convergence Information in .eio file for details. * ~~~ * ...Environment(SizingPeriod)="NEW YORK J F KENNEDY INTL AR ANN HTG 99.6% CONDNS DB" * ~~~ * ..Max Temp Comparison = 7.61E-002 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Min Temp Comparison = 1.44 vs Temperature Convergence Tolerance=0.40 - Fail Convergence * ~~~ * ..Max Heat Load Comparison = 0.4777 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence * ~~~ * ..Max Cool Load Comparison = 2.0753E-002 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence * Severe * CheckWarmupConvergence: Loads Initialization, Zone="CORRIDOOR- LEVEL-3" did not converge after 25 warmup days. * ~~~ * ...Environment(SizingPeriod)="NEW YORK J F KENNEDY INTL AR ANN HTG 99.6% CONDNS DB" * ~~~ * ..Max Temp Comparison = 9.70E-005 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Min Temp Comparison = 6.30E-003 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Max Heat Load Comparison = 7.1441E-003 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence * ~~~ * ..Max Cool Load Comparison = 0.1404 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence * Severe * CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR" did not converge after 25 warmup days. * ~~~ * ...Environment(SizingPeriod)="NEW YORK J F KENNEDY INTL AR ANN HTG 99.6% CONDNS DB" * ~~~ * ..Max Temp Comparison = 9.56E-002 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Min Temp Comparison = 1.71E-004 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Max Heat Load Comparison = 1.8432 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence * ~~~ * ..Max Cool Load Comparison = 0.1714 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence * Severe * CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 1" did not converge after 25 warmup days. * ~~~ * ...Environment(SizingPeriod)="NEW YORK J F KENNEDY INTL AR ANN HTG 99.6% CONDNS DB" * ~~~ * ..Max Temp Comparison = 1.67E-002 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Min Temp Comparison = 1.25E-004 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Max Heat Load Comparison = 0.1147 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence * ~~~ * ..Max Cool Load Comparison = 0.9862 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence * Severe * CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 10" did not converge after 25 warmup days. * ~~~ * ...Environment(SizingPeriod)="NEW YORK J F KENNEDY INTL AR ANN HTG 99.6% CONDNS DB" * ~~~ * ..Max Temp Comparison = 1.75E-005 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Min Temp Comparison = 4.95E-005 vs Temperature Convergence Tolerance=0.40 - Pass Convergence * ~~~ * ..Max Heat Load Comparison = 5.2203E-002 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence * ~~~ * ..Max Cool Load Comparison = 6.1489E-005 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence * Severe * CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 11" did not converge after 25 warmup days.
**   ~~~   **  Environment=NEW YORK J F KENNEDY INTL AR ANN CLG .4% CONDNS DP=>MDB, at Simulation time=07/21 00:00 - 01:00
 * ** Severe  * ** CheckWarmupConvergence: Loads Initialization, Zone="CORRIDOOR- LEVEL-2" did not converge after 25 warmup days.
 *   ~~~   * **   ~~~   ** See Warmup Convergence Information in .eio file for details.
 *   ~~~   * **   ~~~   ** ...Environment(SizingPeriod)="NEW YORK J F KENNEDY INTL AR ANN HTG 99.6% CONDNS DB"
 *   ~~~   * **   ~~~   ** ..Max Temp Comparison = 7.61E-002 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Min Temp Comparison = 1.44 vs Temperature Convergence Tolerance=0.40 - Fail Convergence
 *   ~~~   * **   ~~~   ** ..Max Heat Load Comparison = 0.4777 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence
 *   ~~~   * **   ~~~   ** ..Max Cool Load Comparison = 2.0753E-002 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
 * ** Severe  * ** CheckWarmupConvergence: Loads Initialization, Zone="CORRIDOOR- LEVEL-3" did not converge after 25 warmup days.
 *   ~~~   * **   ~~~   ** ..Max Temp Comparison = 9.70E-005 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Min Temp Comparison = 6.30E-003 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Max Heat Load Comparison = 7.1441E-003 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Max Cool Load Comparison = 0.1404 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence
 * ** Severe  * ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR" did not converge after 25 warmup days.
 *   ~~~   * **   ~~~   ** ..Max Temp Comparison = 9.56E-002 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Min Temp Comparison = 1.71E-004 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Max Heat Load Comparison = 1.8432 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence
 *   ~~~   * **   ~~~   ** ..Max Cool Load Comparison = 0.1714 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
 * ** Severe  * ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 1" did not converge after 25 warmup days.
 *   ~~~   * **   ~~~   ** ..Max Temp Comparison = 1.67E-002 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Min Temp Comparison = 1.25E-004 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Max Heat Load Comparison = 0.1147 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence
 *   ~~~   * **   ~~~   ** ..Max Cool Load Comparison = 0.9862 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
 * ** Severe  * ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 10" did not converge after 25 warmup days.
 *   ~~~   * **   ~~~   ** ..Max Temp Comparison = 1.75E-005 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Min Temp Comparison = 4.95E-005 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
 *   ~~~   * **   ~~~   ** ..Max Heat Load Comparison = 5.2203E-002 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence
 *   ~~~   * **   ~~~   ** ..Max Cool Load Comparison = 6.1489E-005 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
 * ** Severe  * ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 11" did not converge after 25 warmup days.days.
Thanks
** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="CORRIDOOR- LEVEL-2" did not converge after 25 warmup days.
** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="CORRIDOOR- LEVEL-3" did not converge after 25 warmup days.
** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR" did not converge after 25 warmup days.
** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 1" did not converge after 25 warmup days.
** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 10" did not converge after 25 warmup days.
** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="L01-1 BR 11" did not converge after 25 warmup days.
Thanks
