I'm trying to revive an old OpenStudio measure I wrote from a few years back that added the ChillerElectricEIR object to a tertiary loop to function as a heat recovery system so I would end up with a supply-side connection on a chiller water loop and a hot water loop as well as a demand-side connection on a condenser system. We can't manually drag/drop the object in the GUI to a third plant loop so the measure relied on the function 'addToTertiaryNode.' It appears this function is not longer available in the newer versions of OS so I'm looking for something equivalent. Does that function exist?
