Error after importing EnergyPlus Example IDF into OSM
Hi. I am new to EnergyPlus and OpenStudio. I am using it to determine heating and cooling load profiles of various building types. A while ago, I found the Reference Commercial building type 8760 load profiles put out by DOE/NREL i.e. "RefBldgMidriseApartmentNew2004_v1.3_7.1_5A_USA_IL_CHICAGO-OHARE,csv". I want to recreate this (verify) using the similarly named ExampleFiles IDF file in EnergyPlus i.e. "RefBldgMidriseApartmentNew2004_Chicago.idf"
Simulating this within EnergyPlus yields some information i.e. equipment capacity but annual loads show as zero and there is no 8760 profile. So I moved on to OpenStudio. The IDF imports with some warnings about not everything being imported (probably key to this problem) and simulation stops with this error file:
Program Version,EnergyPlus, Version 23.1.0-87ed9199d4, YMD=2023.11.28 10:33, * Severe * <root>[AirTerminal:SingleDuct:ConstantVolume:NoReheat][G N1 Apartment Direct Air] - Missing required property 'air_inlet_node_name'. * Severe * <root>[AirTerminal:SingleDuct:ConstantVolume:NoReheat][G N1 Apartment Direct Air] - Missing required property 'air_outlet_node_name'. * Severe * <root>[ZoneHVAC:AirDistributionUnit][ADU G N1 Apartment Direct Air] - Missing required property 'air_distribution_unit_outlet_node_name'. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=3 ..... Last severe error=<root>[ZoneHVAC:AirDistributionUnit][ADU G N1 Apartment Direct Air] - Missing required property 'air_distribution_unit_outlet_node_name'. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.19sec
I have learned a lot about the workings of EP and OS chasing down the solution with IDF Editor and other tools, but I am stumped. If someone can recreate what I did (with the example idf), I would appreciate that.
Thanks,
Todd K.
Thanks,
Todd K.
Program
*Program Version,EnergyPlus, Version 23.1.0-87ed9199d4, YMD=2023.11.28 10:33,
   * Severe  * ** Severe  ** <root>[AirTerminal:SingleDuct:ConstantVolume:NoReheat][G N1 Apartment Direct Air] - Missing required property 'air_inlet_node_name'.
   * Severe  * ** Severe  ** <root>[AirTerminal:SingleDuct:ConstantVolume:NoReheat][G N1 Apartment Direct Air] - Missing required property 'air_outlet_node_name'.
   * Severe  * ** Severe  ** <root>[ZoneHVAC:AirDistributionUnit][ADU G N1 Apartment Direct Air] - Missing required property 'air_distribution_unit_outlet_node_name'.
   * **  Fatal  * ** Errors occurred on processing input file. Preceding condition(s) cause termination.
 *** ************* Warning:  Node connection errors not checked - most system input has not been read (see previous warning).
 *** ************* Fatal error -- final processing.  Program exited before simulations began.  See previous error messages.
 *** ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
 *** ************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
 *** ************* EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 3 Severe Errors; Elapsed Time=00hr 00min  0.19sec
0.19sec*
Thanks,
Todd K.
Update! I found a different approach that seems to work. After searching "OpenStudio example files", I came across this... UserQuickStartGuide.md
After loading the suggested measure and running it, I now have an OSM model that compiles for a DOE reference building MidRiseApt in Chicago. I am still interested in hearing comments on why my initial approach failed.
**  Fatal  ** Errors occurred on processing input file. Preceding condition(s) cause termination.
************* EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 3 Severe Errors; Elapsed Time=00hr 00min  0.19sec*
Thanks,
Todd K.
