Hi, I am trying to model a crankcase heater controller that contains three temperature sensors: 1) compressor discharge temperature, 2) evaporator coil temperature, 3) outdoor air temperature. I can obtain outdoor drybulb temperature as an output using Output:Variable object. Does anyone know if I can get compressor discharge temperature and evaporator coil temperature as outputs?
