I have installed Sketchup Pro 17 and Euclid, to use Energyplus 22.1. Then, I installed Openstudio v 2.9.1, as advised on GitHub, to use Openstudio. Then I opened sketchup, it appeared for a while and then disappeared. I also tried installing v 2.9.0. It happend the same.
Can we use both openstudio and euclid, with Sketchup Pro 17? Thank you for any suggestion in advance.
