is it possible in energyplus to transfer electricity from building which has off-grid system to the power grid? how can I define that in energy plus? with transformer or other parameter?
| 1 | initial version |
| 2 | retagged |
Hi, through which variable I could get the data for power grid in the building? also I define PV panels and battery for the building is it possible in energyplus supposed to transfer electricity be an off-grid or on-grid since the amount of energy comes from building which has off-grid system to the power grid? how can I define that in energy plus? with transformer or other parameter?utilities are zero?
Hi, through which variable how can I could get the data output for power grid in the building? also I define PV panels and battery for the building is it supposed to be an off-grid or on-grid since the amount of energy comes electricity transferred by the power generator from utilities are zero?the grid?
