Hello, expert.
I'm using macos M1 (arm) I'm trying to connect sketchup to openstudio.
If there is a problem, please tell me which part is the problem.
What I installed: OpenStudio-3.6.1 / OpenStudioApplication-1.6.0 / SketchUp 2023
plugin download(SketchUp Plugin v1.6.0) : https://github.com/openstudiocoalition/openstudio-sketchup-plugin/releases/tag/v1.6.0-rc.1
What I'm working on 1. Installation of the above 2. Install SketchUp Plugin v1.6.0 (.rbz) in the Sketchup Extension Manager 3. path to Openstudio Root (/Applications/OpenStudioApplication-1.6.0)
Number 3 is not performed. (Please refer to the attached photo below.)
https://github.com/openstudiocoalition/openstudio-sketchup-plugin/tree/develop I found this link, but I don't know how to use it. If you need to use the link above, please tell me which folder part to use
Translation can be awkward. Thank you for your help.
