I made a VRF system to supply cooling and heating services for a zone by using openstudio. Next I want my RL program contorl the zone thermalstat setpoint ,humidity setpoint and fan speed of VRF terminal. What should I do? The following are VRF settings, ThermostatSetpoint and coil settings.
ZoneHVAC:TerminalUnit:VariableRefrigerantFlow, KN-09_B1_Locker_F, !- Zone Terminal Unit Name Always On Discrete hvac_library, !- Terminal Unit Availability Schedule Node 148, !- Terminal Unit Air Inlet Node Name Node 149, !- Terminal Unit Air Outlet Node Name Autosize, !- Cooling Supply Air Flow Rate {m3/s} Autosize, !- No Cooling Supply Air Flow Rate {m3/s} Autosize, !- Heating Supply Air Flow Rate {m3/s} Autosize, !- No Heating Supply Air Flow Rate {m3/s} 0, !- Cooling Outdoor Air Flow Rate {m3/s} 0, !- Heating Outdoor Air Flow Rate {m3/s} 0, !- No Load Outdoor Air Flow Rate {m3/s} Always On Discrete hvac_library, !- Supply Air Fan Operating Mode Schedule Name DrawThrough, !- Supply Air Fan Placement Fan:OnOff, !- Supply Air Fan Object Type VRF Zone Terminal Fan 5, !- Supply Air Fan Object Name , !- Outside Air Mixer Object Type , !- Outside Air Mixer Object Name Coil:Cooling:DX:VariableRefrigerantFlow, !- Cooling Coil Object Type VRF Zone Terminal Cooling Coil 5, !- Cooling Coil Object Name Coil:Heating:DX:VariableRefrigerantFlow, !- Heating Coil Object Type VRF Zone Terminal Heating Coil 5, !- Heating Coil Object Name 30, !- Zone Terminal Unit On Parasitic Electric Energy Use {W} 20, !- Zone Terminal Unit Off Parasitic Electric Energy Use {W} 1, !- Rated Heating Capacity Sizing Ratio {W/W} , !- Availability Manager List Name , !- Design Specification ZoneHVAC Sizing Object Name , !- Supplemental Heating Coil Object Type , !- Supplemental Heating Coil Name Autosize, !- Maximum Supply Air Temperature from Supplemental Heater {C} 21; !- Maximum Outdoor Dry-Bulb Temperature for Supplemental Heater Operation {C}
AirConditioner:VariableRefrigerantFlow, KW-6, !- Heat Pump Name Always On Discrete hvac_library, !- Availability Schedule Name 117500, !- Gross Rated Total Cooling Capacity {W} 3.47, !- Gross Rated Cooling COP {W/W} -5, !- Minimum Condenser Inlet Node Temperature in Cooling Mode {C} 54, !- Maximum Condenser Inlet Node Temperature in Cooling Mode {C} VRF System VRFCoolCapFT 6, !- Cooling Capacity Ratio Modifier Function of Low Temperature Curve Name VRF System VRFCoolCapFTBoundary 6, !- Cooling Capacity Ratio Boundary Curve Name VRF System VRFCoolCapFTHi 6, !- Cooling Capacity Ratio Modifier Function of High Temperature Curve Name VRF System VRFCoolEIRFT 6, !- Cooling Energy Input Ratio Modifier Function of Low Temperature Curve Name VRF System VRFCoolEIRFTBoundary 6, !- Cooling Energy Input Ratio Boundary Curve Name VRF System VRFCoolEIRFTHi 6, !- Cooling Energy Input Ratio Modifier Function of High Temperature Curve Name VRF System CoolingEIRLowPLR 6, !- Cooling Energy Input Ratio Modifier Function of Low Part-Load Ratio Curve Name VRF System CoolingEIRHiPLR 6, !- Cooling Energy Input Ratio Modifier Function of High Part-Load Ratio Curve Name VRF System CoolingCombRatio 6, !- Cooling Combination Ratio Correction Factor Curve Name VRF System VRFCPLFFPLR 11, !- Cooling Part-Load Fraction Correlation Curve Name 132000, !- Gross Rated Heating Capacity {W} 1, !- Rated Heating Capacity Sizing Ratio {W/W} 3.89, !- Gross Rated Heating COP {W/W} -25, !- Minimum Condenser Inlet Node Temperature in Heating Mode {C} 27, !- Maximum Condenser Inlet Node Temperature in Heating Mode {C} VRF System VRFHeatCapFT 6, !- Heating Capacity Ratio Modifier Function of Low Temperature Curve Name VRF System VRFHeatCapFTBoundary 6, !- Heating Capacity Ratio Boundary Curve Name VRF System VRFHeatCapFTHi 6, !- Heating Capacity Ratio Modifier Function of High Temperature Curve Name VRF System VRFHeatEIRFT 6, !- Heating Energy Input Ratio Modifier Function of Low Temperature Curve Name VRF System VRFHeatEIRFTBoundary 6, !- Heating Energy Input Ratio Boundary Curve Name VRF System VRFHeatEIRFTHi 6, !- Heating Energy Input Ratio Modifier Function of High Temperature Curve Name WetBulbTemperature, !- Heating Performance Curve Outdoor Temperature Type VRF System HeatingEIRLowPLR 6, !- Heating Energy Input Ratio Modifier Function of Low Part-Load Ratio Curve Name VRF System HeatingEIRHiPLR 6, !- Heating Energy Input Ratio Modifier Function of High Part-Load Ratio Curve Name VRF System HeatingCombRatio 6, !- Heating Combination Ratio Correction Factor Curve Name VRF System VRFCPLFFPLR 12, !- Heating Part-Load Fraction Correlation Curve Name 0.25, !- Minimum Heat Pump Part-Load Ratio {dimensionless} , !- Zone Name for Master Thermostat Location LoadPriority, !- Master Thermostat Priority Control Type , !- Thermostat Priority Schedule Name KW-6 Terminal List, !- Zone Terminal Unit List Name No, !- Heat Pump Waste Heat Recovery 30, !- Equivalent Piping Length used for Piping Correction Factor in Cooling Mode {m} 10, !- Vertical Height used for Piping Correction Factor {m} VRF System CoolingLengthCorrectionFactor 6, !- Piping Correction Factor for Length in Cooling Mode Curve Name -0.000386, !- Piping Correction Factor for Height in Cooling Mode Coefficient {1/m} 30, !- Equivalent Piping Length used for Piping Correction Factor in Heating Mode {m} VRF System HeatingLengthCorrectionFactor 6, !- Piping Correction Factor for Length in Heating Mode Curve Name 0, !- Piping Correction Factor for Height in Heating Mode Coefficient {1/m} 15, !- Crankcase Heater Power per Compressor {W} 3, !- Number of Compressors {dimensionless} 0.33, !- Ratio of Compressor Size to Total Compressor Capacity {W/W} 7, !- Maximum Outdoor Dry-Bulb Temperature for Crankcase Heater {C} Resistive, !- Defrost Strategy Timed, !- Defrost Control , !- Defrost Energy Input Ratio Modifier Function of Temperature Curve Name 0.058333, !- Defrost Time Period Fraction {dimensionless} 1e-07, !- Resistive Defrost Heater Capacity {W} 7, !- Maximum Outdoor Dry-bulb Temperature for Defrost Operation {C} AirCooled, !- Condenser Type , !- Condenser Inlet Node Name , !- Condenser Outlet Node Name Autosize, !- Water Condenser Volume Flow Rate {m3/s} 0.9, !- Evaporative Condenser Effectiveness {dimensionless} Autosize, !- Evaporative Condenser Air Flow Rate {m3/s} Autosize, !- Evaporative Condenser Pump Rated Power Consumption {W} , !- Supply Water Storage Tank Name 0, !- Basin Heater Capacity {W/K} 2, !- Basin Heater Setpoint Temperature {C} , !- Basin Heater Operating Schedule Name Electricity, !- Fuel Type 0, !- Minimum Condenser Inlet Node Temperature in Heat Recovery Mode {C} 27, !- Maximum Condenser Inlet Node Temperature in Heat Recovery Mode {C} VRF System Heat Recovery Cooling Cap Modifier 6, !- Heat Recovery Cooling Capacity Modifier Curve Name 1, !- Initial Heat Recovery Cooling Capacity Fraction {W/W} 0.083, !- Heat Recovery Cooling Capacity Time Constant {hr} VRF System Heat Recovery Cooling Energy Modifier 6, !- Heat Recovery Cooling Energy Modifier Curve Name 1, !- Initial Heat Recovery Cooling Energy Fraction {W/W} 0, !- Heat Recovery Cooling Energy Time Constant {hr} VRF System Heat Recovery Heating Cap Modifier 6, !- Heat Recovery Heating Capacity Modifier Curve Name 0.5, !- Initial Heat Recovery Heating Capacity Fraction {W/W} 0.083, !- Heat Recovery Heating Capacity Time Constant {hr} VRF System Heat Recovery Heating Energy Modifier 6, !- Heat Recovery Heating Energy Modifier Curve Name 0.5, !- Initial Heat Recovery Heating Energy Fraction {W/W} 0; !- Heat Recovery Heating Energy Time Constant {hr}
ThermostatSetpoint:DualSetpoint, Thermostat Setpoint Dual Setpoint 7, !- Name Small Office HtgSetp, !- Heating Setpoint Temperature Schedule Name Small Office ClgSetp; !- Cooling Setpoint Temperature Schedule Name
Coil:Cooling:DX:VariableRefrigerantFlow, VRF Zone Terminal Cooling Coil 12, !- Name Small Office ClgSetp, !- Availability Schedule Name 5600, !- Gross Rated Total Cooling Capacity {W} Autosize, !- Gross Rated Sensible Heat Ratio 0.233, !- Rated Air Flow Rate {m3/s} VRFTUCoolCapFT, !- Cooling Capacity Ratio Modifier Function of Temperature Curve Name VRFACCoolCapFFF, !- Cooling Capacity Modifier Curve Function of Flow Fraction Name Node 162, !- Coil Air Inlet Node KN-10_HighVolt_Dist1 Cooling Coil Outlet Node; !- Coil Air Outlet Node
Coil:Heating:DX:VariableRefrigerantFlow, VRF Zone Terminal Heating Coil 12, !- Name Small Office HtgSetp, !- Availability Schedule 6300, !- Gross Rated Heating Capacity {W} 0.233, !- Rated Air Flow Rate {m3/s} KN-10_HighVolt_Dist1 Cooling Coil Outlet Node, !- Coil Air Inlet Node KN-10_HighVolt_Dist1 Heating Coil Outlet Node, !- Coil Air Outlet Node Coil Heating DX Variable Refrigerant Flow 1 VRFTUHeatCAPFT, !- Heating Capacity Ratio Modifier Function of Temperature Curve Name Coil Heating DX Variable Refrigerant Flow 1 VRFACCoolCapFFF; !- Heating Capacity Modifier Function of Flow Fraction Curve Name
