Hi,
I was wondering if anyone could please help on the Surface Construction Index output variable. More specifically, I need to identify the equaivalent surfaces that I'm geeting under each Surface Construction Index, per timestep - where my construction is subject to change using an EMS Program.
I already added the Output:Diagnostics to the idf. However, I'm not sure how to interperate the surface constuction names, such as 35, 37,.... I tried to match those surfaces in the .eio file, but I was not able to find them.
Thanks, Mohammad
