Do not have the chilled water loop option for the cooling coil
I need to connect the cooling coil to a Plant Loop, but I can not see the "chilled water loop" option when I click on the coil object on the diagram to select it. I shared the related screenshot and a URL for the file itself.
I can not see any cooling load in the results tab when I run the simulation and I believe it is related to the problem I explained above. I would appreciate any help.
URL for the .osm file: https://drive.google.com/drive/folders/1Q1uPoa1zxi8KPB22A8ElBktLPgtFpTJ4?usp=sharing
