Hello everyone,
I've encountered an issue while trying to use the Brick-Fired Clay material from BCL in OpenStudio. I successfully downloaded the material, and it appears in the library window on the right side of OpenStudio. However, when I attempt to drag and drop it into the related box in the constructions tab, nothing happens.
The program doesn't crash or display an error message, but the material also doesn't appear anywhere within the model. It remains visible only inside the library tab.
I would greatly appreciate any assistance on how to properly apply the Brick-Fired Clay material to my construction. If you need more information about my setup please let me know.
