Hello,
I'm currently modeling the 5th floor of a building on EnergyPlus. It crashed on the first try without giving a .err file. After looking for an answer on this forum, I finally tried to find the problem by my own means. I found that very strangely, the WindowShadingControl item "OccultationSolaireClOuest" applied to the window named "ClasseOuestFenOuest" was the reason of the crash. However, I didn't managed to understand why it causes the crash. I tried to change every parameter I thought of, without success. If someone has an answer to this question, it would be awesome!
Thank you in advance. P.S: The idf file, osm file (just used for drawing the geometry) and a picture of the model are available here : https://drive.google.com/drive/folders/1nygAP4o6AIV2fXYvqVeIQREXOrFyjR3e?usp=drive_link
