When attempting to select my baseline model in the Parametric Analysis Tool (PAT), I receive the following error:
Unhandled Exception
An unhandled exception has occurred.
boost::filesystem::copy_file: Acess is denied: "C:/Users...\test.osm", "C:/Users...\PATtest\seed\test.osm"
When I check the "seed" folder, however, I do see that the "test.osm" file has been copied over. Any suggestions would be greatly appreciated.
