Hi All,
I'm conducting a study on the heating and cooling demand of a building, and I'm using the "sensible heat gain summary" report for it.
My issue is that I need to obtain the values from the "HVAC Zone Eq & Other Sensible Air Heating (W)"column for the entire year. I've been looking at the input/output reference document, but it seems like the variables are outdated, and I can't find the variables I should use in the "output:variable" section to get the same value from this column for each hour of the year.
(I'm using HVACTemplate:Zone:IdealLoadsAirSystem)
Thanks for your attention.
