Working on a 4-story multifamily with a very small tenant office space (hence not modeled as a separate non-res building story). I just finished clearing some geometry errors but now getting new set of errors. I have gone through all the inputs on envelope & mechanical tabs to see if any assignment is wrong or any data is missing or if there are any 0 cfms, but still unable to find what might be causing especially #3,4. Any insights into what I should be doing to fix all these errors would be greatly appreciated.
Software version - CBECC 2022.3.0 (1302)
These 7 errors mentioned below appear many times causing over 160 errors before the program can simulate -
Error Type 1: RetrieveCSVValue() error: unable to open CSV file: C:\Users\sborle\Documents\CBECC 2022 Projects\FairviewTerraces\FairviewTerrace - run\FairviewTerrace - zp-hvacSzg.csv evaluating run zp rule: Rule 51, 1, 'Rules_PostSim.rule' Line 44: Retrieve AirSys:SupAirSegRef:CoilHtgRef:CapTotGrossRtdSim from CSE sizing results
Error Type 2: RetrieveCSVValue() error: unable to open CSV file: C:\Users\sborle\Documents\CBECC 2022 Projects\FairviewTerraces\FairviewTerrace - run\FairviewTerrace - zb-hvacSzg.csv evaluating run zb rule: Rule 52, 1, 'Rules_PostSim.rule' Line 101: Retrieve AirSys:SupAirSegRef:CoilHtgRef:CapTotGrossRtdSim from CSE sizing results
Error Type 4: Undefined data: right side of '*' evaluating run ap rule: Set ANNUAL_PROPOSED AirSys:AirSeg:Fan:MtrBHPStart (96:'HVACSecondary-Fan-ReturnRelief-T24N.rule' line 182)
Error Type 5: Undefined data: left side of '*' evaluating run ab rule: Set ANNUAL_BASELINE CoilHtg:HtPumpCOP17Adj (90:'HVACSecondary-CoilHeating-HeatPump.rule' line 1108)
Error Type 6: RetrieveCSVValue() error: unable to open CSV file: C:\Users\sborle\Documents\CBECC 2022 Projects\FairviewTerraces\FairviewTerrace - run\FairviewTerrace - ap-znUMLHs.csv evaluating run ap rule: Rule 53, 1, 'Rules_PostSim.rule' Line 149: Retrieve ResZn Cooling UMLHs from CSE export for P run(s)
Error Type 7: RetrieveCSVValue() error: unable to open CSV file: C:\Users\sborle\Documents\CBECC 2022 Projects\FairviewTerraces\FairviewTerrace - run\FairviewTerrace - ap-znUMLHs.csv evaluating run ap rule: Rule 53, 2, 'Rules_PostSim.rule' Line 153: Retrieve ResZn Heating UMLHs from CSE export for P run(s)
Thanks
