Hello, in my building model there are more than 600 surfaces of which about 300 are walls with same construction. Is there a effective method to set the construction all together instead of do that one by one?
Thanks =)
| 1 | initial version |
Thanks =)
| 2 | No.2 Revision |
Is there a effective method to set the construction all together instead of do doing that one by one?
Thanks =)
