I created a building without hvac system to see how room temperature change camparing to real-world data with openstudio 2.9 and sketchup 2017.but as you can see in picture.the zone air heat surface convection rate of room 104 105 204 205 is much higher comparing to other room. I checked the boundary condition and material all the rooms are very similar I wonder what makes this problem and how to fix this?
