I'm aware of the CLI to calculate an OpenStudio model. But I'm working on an interface that may require the use of the OpenStudio application UI, to view defaults etc.
I have experimented with just calling the OpenStudioApp.exe, and passing it a file name as a parameter which works and opens the expected file. But if for example I'm after opening a model, and setting the UI to be on something specific, is there any support for this.
For example programmatically I can set a setpoint heating schedule for a model, but would like to be able to fire up the application, have the appropriate tab open up, and for it to have the chosen heating Set point schedule on screen. I Cant find any documentation on this.
I can use shellexecute etc to start it up and open a file, but not in specific tab or area of the UI thereafter?
