Hi,
I was wondering if anyone could help me with the following EnergyPlus question. More specifically, I'm modeling a water heater object for a single-family model (WaterHeater:Mixed). While the model ran successfully, I found the following error, that has repeated for each fixture: Target water temperature should be less than or equal to the hot water temperature error continues... * ~~~ * ...target water temperature = 48.89 C * ~~~ * ...hot water temperature = 47.58 C
I tied tor esolve that error by appying the following potential resolutions, but non of them worked:
- Incresed the setpoint SetPointManger:Scheduled
- Increased Maximum Temperature Limit
Any suggestions will be greatly appreciated!
Thanks, Mohammad
