Hi,
In ResStock documentation it is mentioned that "If a custom buildstock.csv file is located in a project’s housing_characteristics directory when you run the project, it will automatically be used to generate simulations. If it’s not found, the sampling will be run automatically to create one." However, when I am running resstock locally using buildstockbatch_local, every time it is performing the sampling again. Is there anyway to use the existing buildstock.csv file?
