Hi, I have a model with a multiple AirLoops in series.
The model consists in a primary air AirLoop (AHU-1) feeding multiple VRF terminal units and two other AirLoops (AHU-2 and AHU-3). I have made the outside air AirLoop connected to the VRF but I don't know how to connect it to the other two. Is there a possibility to realize to connect two AirLoops in series in OpenStudio? How could it be done? If it is not possible, is it a valid solution to use a unitary system in the zone?
Thanks!
