Hello, I am trying to set up a remote server to run algorithmic analysis using the parametric analysis tool (v3.6.0). According to the according to the github documentation, the prerequisites for setting up a server are
- Kubernetes 1.22+
- Helm Client(v3.12.0 or higher)
kubectl client (v1.27.0 or higher)
I have successfully created an AWS account and have installed eksctl. I am now at the "creating a cluster using eksctl" portion of the documentation and it prompts me to provide eksctl access to AWS by setting up ENV variables by running the cli example.
Where do I run these commands? I tried running them in the command promt but they are not recognized as commands.
Any help on getting the OpenStudio Server set up would be greatly appreciated.
Thank you!
