1.At first, I set it up like this in Generator:Photovoltaic name PVwindow surface name Sub Surface 1 Photovoltaic Performance Object Type PhotovoltaicPerformance:EquivalentOne-Diode Module Performance Name IntegratedSurfaceOutsideFace .....
2.But the following error occurs: Must use a surface with internal source construction for IntegratedSurfaceOutsideFace mode in PVwindow1 3.Then, I put my ConstructionProperty: InternetHeatSource Construction in the name changed to pv window, but the energyplus tip error: Windows are not allowed to have embedded sources/sinks. 4.Finally, I change the Construction name to that of the external wall and the Surface name of the Generator:Photovoltaic to that of the wall corresponding to the window, which will work. But ths should not be correct, if anyone knows what the correct setting is, please let me know. Thanks!
