I used the calculation method (UHFcalc) available in EnergyPlus to calculate the g-function response factors of the ground heat exchangers.
I would like to know if there is any possible way to know the values of response factors calculated and results from using this method in energyPlus.
Thank you,
Regards,
Kamar
