Unitary System: Missing required property 'air_inlet/outlet_node_name'
Hi,
I am trying to model packaged single zone heat hump systems (System 4) per ASHRAE 90.1 Appendix G. I use the "Unitary - DX Heat Pump (Two Speed cooling) - Cycling - Elec reheat" object from the library. It has been fine for the first two zones but then when I continue to do the same for the third zone onwards, I have got the following error.
Could anyone please advise why I start to get this error even though I use the same object and modeling method that do not give any error with the two previous zones?
Thank you.
Program Version,EnergyPlus, Version 23.1.0-87ed9199d4, YMD=2023.08.01 20:05,
** Severe  ** <root>[Coil:Cooling:DX:TwoSpeed][2 Spd DX Clg Coil 5] - Missing required property 'air_inlet_node_name'.
** Severe  ** <root>[Coil:Cooling:DX:TwoSpeed][2 Spd DX Clg Coil 5] - Missing required property 'air_outlet_node_name'.
**  Fatal  ** Errors occurred on processing input file. Preceding condition(s) cause termination.
Hi,
I am trying to model packaged single zone heat hump systems (System 4) per ASHRAE 90.1 Appendix G. G using OpenStudio. I use the "Unitary - DX Heat Pump (Two Speed cooling) - Cycling - Elec reheat" object from the library. It has been fine for the first two zones but then when I continue to do the same for the third zone onwards, I have got the following error.
Thank you.
Hi,
I am trying to model packaged single zone heat hump systems (System 4) per ASHRAE 90.1 Appendix G using OpenStudio. I use the "Unitary - DX Heat Pump (Two Speed cooling) - Cycling - Elec reheat" object from the library. It has been fine for the first two zones but then when I continue to do the same for the third zone onwards, I have got the following error.
Thank you.
OpenStudio - Unitary System: Missing required property 'air_inlet/outlet_node_name'
Hi,
Thank you.
Hi,
Thank you.
Hi,
Thank you.
