plant loop volume too small
Hi everyone!
I am making a building model with underfloor heating system with boiler as the heat source for the hot water. I have set the plant loop volume to "Autocalculate," but the Performance Summary indicates that the "plant loop volume" is too small (0.020103 m³)
What variables or inputs should I check to identify the reason for the small plant loop volume?
Hi everyone!
Hi everyone!
I am making a building model in DesignBuilder with underfloor heating system with boiler as the heat source for the hot water. I have set the plant loop volume to "Autocalculate," but the Performance Summary indicates that the "plant loop volume" is too small (0.020103 m³)
What variables or inputs should I check in EnergyPlus or DesignBuilder to identify the reason for the small plant loop volume?
